Posted by iViLL
Trigon
can't remote control from v12 installed to Insider builds v13 installed pc
incompatible version, please fix, i can't remote control from android anymore, could you keep the version in balance or at least drop a teamviewer for android in google play beta test
1 Accepted Solution
Accepted Solutions
Posted by Cinu
Digon
Solution
Re: can't remote control from v12 installed to Insider builds v13 installed pc
TeamViewer 13 already available for Android.
You need to join this group https://plus.google.com/communities/107677999878582587278
Then under group description, you need to click Download TeamViewer Android Beta App
After a while you will have an update for TeamViewer available.
Posted by iViLL
Trigon
when will you upgrate tv for android to v13, if you do not got an answer, i should roll back my pc client from v13 beta to v12
Posted by Cinu
Digon
Solution
