reviewer using two PCs via a tp cable
Highlighted
Posted by
Trigon
I cannot use the one PC on internet. Both has teamviewer installed. I have a cable between them and can use Remote Desktop.
But then the one machine cannot be used as you are able using teamviewer.
How do I set up teamviewer on the two machine to make it work?
1 Reply
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by
Trigon
Solution
Re: reviewer using two PCs via a tp cable
I fo
I found the answer and it was very simple.
https://community.teamviewer.com/t5/Knowledge-Base/Can-TeamViewer-be-used-within-a-local-network-LAN...
View solution in original post
1 Reply
Highlighted
Posted by
Trigon
Solution
I fo
