Posted by Mesterbob
Henagon
session timeout after 30 seconds only from my laptop?
So i just updated to newest teamviewer version on my laptop and right after it started getting dropped after maximum 30 seconds, sometimes less, when i connect to my other pc.
It just says connection timeout, then when i try to reconnect it says that my connection is blocked after the time out and that i cannot login for the next 20 min. after the time i can connect again, but only for a couple of seconds and then it gets blocked for 20 min again.
When i connect using my phone there is no problem at all.
Anyone know whats happening?
I have a hard time finding out where i can contact the teamviewer team, so therefore im trying here.
1 Accepted Solution
Accepted Solutions
Posted by Mesterbob
Henagon
Solution
Re: session timeout after 30 seconds only from my laptop?
Ahh, now i got the "we have registered commercial use" i will try to write to them via https://www.teamviewer.com/en/support/personal-use-verification/?_ga=2.148219575.108035635.153391012...
Posted by Mesterbob
Henagon
Solution
Posted by smash591
Henagon
I do not have the commercial use detected message but I cannot use TeamViewer for more than 30 seconds (all of a sudden). It worked yesterday just fine.
