should current teamviewer 15 be able to connect to a device with teamviewerqs 10?
I have an older ipad that cannot be updated anymore, it hasTeamviewerQS ver 10.
When I try to connect, I get the error: The remote TeamViewer is running anold version which is out of date. Therefore you cannot connect to this version anymore. Your connection partner can update Teamviewer by clicking on "Help" - "Check for new version"
Can anyone help with this?
Is it possible to have an older verion and anewer versioninstalledonthe same machine?
  • Esther
    HI @eyeguy1
    Thanks for your question.
    Connections to older versions are only possible in case a TeamViewer license is active on your account.
    In case you or your connection partner do not have a license, a connection will only be possible if both devices use TeamViewer in the latest version (version 15).
    You can find more information here: Updating to the latest and greatest version of TeamViewer.
    Esther
