Announcements
Did you already try the new Windows 10 October 2020 Update?
Share your feedback and experience with TeamViewer on the new Windows build with our developers here.
Highlighted
Posted by TeamViewer Star
TeamViewer Star
TeamVierwer CMD - connection to the TVHost with EasyAccess without --Password
I'm logged to my TVAccount, I have set up EasyAcces to Remote TVHost on my clients Server.
I'm using this:
teamviewer.exe -i <ID> --Password <Password>
https://www.teamviewer.com/en/help/91-gibt-es-aufrufparameter-fuer-teamviewer
But without --Password parameter just like this:
Question: Why TVApp asking me for password ?
Whteher the is intended effect of TeamViewer or thing that can fix it ?
If it can be changed: TVMod: Please move it to the IDEAS and treat it as a FeatureRequest.
mLipok
mLipok , AutoIt MVP
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by TeamViewer Staff
TeamViewer Staff
Solution
RE: TeamVierwer CMD - connection to the TVHost with EasyAccess without --Password
Dear mLipok,
To use EasyAccess (remote session without password) to your assign devices you need the authorization via TeamViewer account.
In command line you have no account information, therefore you need to enter password. :smileyhappy:
I’ll move your feature request to the ideas board and forwarded your suggestion to our product management.
Reyhan
View solution in original post
Highlighted
TeamViewer Staff
Solution
Dear mLipok,
Reyhan
Highlighted
TeamViewer Star
Re: RE: TeamVierwer CMD - connection to the TVHost with EasyAccess without --Password
Thanks for your answer.
I was thinking as I was loged to my account, then using from command line should use my current logedi account.
It seemed to me quite reasonable.
For that I thank you for moving this to product manager.
mLipok , AutoIt MVP
Highlighted
TeamViewer Star
Dear @Reyhan do you have any information about what product managmenet said ?
mLipok , AutoIt MVP
Highlighted
TeamViewer Star
Related:
https://community.teamviewer.com/t5/TeamViewer-General/TeamViewer-auto-connection-from-command-line/...
mLipok , AutoIt MVP
Highlighted
TeamViewer Star
This IDEA / FEATURE REQUEST is related to GPDR .
Please make it happend.
mLipok , AutoIt MVP
Highlighted
Posted by
Digon
2020 an still the same Problem
TeamViewer connect via cmd ask for password  !!!!!
EasyAccess is set
TeamViewer Account logged in.
Can you please fix this !!
Highlighted
TeamViewer Star
Any news from here ?
mLipok , AutoIt MVP
