Announcements
Here you will find the download links for all modules
in version 9: TeamViewer 9
Posted by DomLan
Heptagon
Add info to API reference manuale
the detail provided by your development department on the request
https://community.teamviewer.com/t5/API-and-Scripting/API-rate-limit/m-p/3343#U3343
deserves to be reported in the literature (start from manual > 1.4.1)
Domenico Langone
MCSD: App Builder
1 Accepted Solution
Accepted Solutions
Posted by Community Manager
Solution
Re: Add info to API reference manuale
Hi @DomLan
Thank you for your idea.
I am happy to tell you, that we will integrate the new details into the next release of our API manual.
Esther
Find this helpful? Say thanks by clicking on the Thumbs Up button. Find more information here: Knowledge Base | Community Blog | How to get started
View solution in original post
Solution
Hi @DomLan
Esther
Posted by mLipok
Heptagon
Is it exist already ?
API Doc v1.4.1 Chapter 1.7 Rate Limits   Page 14
License Rate limit per API call
Free 300 requests per hour
Business 600 requests per hour
Premium 1,200 requests per hour
Corporate 3,000 requests per hour
mLipok , AutoIt MVP
Posted by DomLan
Heptagon
Hi mLipok,
in manual exist only the table with linear data. Please visit the post and look for high detail in counting request system. This is the detail required for integration.
Bye.
Domenico Langone
MCSD: App Builder
Posted by mLipok
Heptagon
Ah I see now the most important was this :
The limit is calculated per Api AccessToken per API VERB (GET; POST;PUT;DELETE) per APICALL (/account, /groups /contacts etc.)
so for every combination you have 3000 calls per hour. 3000 GET Account, 3000 GET Groups and so on.
mLipok , AutoIt MVP
