Announcements
Become a product development partner for TeamViewer. Read more about it in our Announcement.
Posted by BornData
Digon
Allow to disable sound on Teamviewer android
Hello Teamviewer,
I would be really happy if you please can make it possible to turn on/off sound from remote unit, like you can make a remote reboot, or press ctrl + alt + delete from tools menu.
Best regards
BornData
Posted by Senior Moderator Senior Moderator
Senior Moderator
Re: Allow to disable sound on Teamviewer android
Hi BornData!
You can disable the sounds before making a connection by going to Options (The little Cog) in the main window of the app and unselecting "Play computer sounds and music" under "Advanced".
However I will add this as a feature request for you, can I ask that anyone else who is after this request please "Kudo" BornData's original post?
Thanks and I hope this helps!
-Scotty
Senior Moderator
Posted by BornData
Digon
Yes, I know you can change the "default" settings.
But I made this request to make easy to turn on/off sound when doing remote support.
If I have sound turned on by default, it will be usefull in most situations, but sometimes I connect to units, where they etc. turned on web radio, and muted their sound, but teamviewer will play the sound (etc. radio) in my headset that im using to talk with my client in, by phone.
So when you from android is doing both teamviewer session and a call on same time, this can be problematic.
Best regards
BornData
