Highlighted
Posted by
Trigon
Moving Connection Tabs
It would be helpful if we could move connection tabs at top of screen to different positions. E.g., if there are a number of connections open and the order is important for efficiency rebooting and reconnecting to a host causes that connection to appear at the end which destroys the priority order. Should be able to simply "grab" the tab and move it, like you can in browsers.
Highlighted
Posted by Community Manager
Re: Moving Connection Tabs
Hi @brw111
Good idea :-)
I move your post in the ideas board as it is at the moment a feature request.
Esther
Find this helpful? Say thanks by clicking on the Thumbs Up button. Find more information here: Knowledge Base | Community Blog | How to get started
Highlighted
Posted by
Photon
I came here just for this option. I use a program that has menu options along the right side of my screen and the connection tab hides two or three options. I can make the window smaller, but viewed through Team Viewer it already seems small enough.
Highlighted
Posted by
Henagon
Yes, I have this problem also. I was just helping someone with a process on their Mac computer via TeamViewer and needed to click on their Hard Drive icon which is positioned at the top rght of the screen. But the TV Connection window was over the top of it and I couldn't find a way to move or minimise the TV window. Very frustrating -it would be good to have a solution to this.
Highlighted
Posted by
Digon
This IS a feature request. :)   So, what is the difference for you between Ideas and feature requests?  very confused on your suggestion, let me know.  Thanks
