Announcements
Shape the future of the TeamViewer product with our Product Team. Click here to join!
Posted by DomLan
Heptagon
Same login (logic) interface
I would like to note that the login operation, performed by different contexts to your services, it should have a homogeneous interface.
In particular, the captcha control should be the last element required to the person before the login prompt.
The management console provides authentication to a different location for the check stays connected, which should appear immediately instead after the textbox for the password (as run by login to the community)
Also use the same font (name, size and style) helps to recognize how unique your authentication system.
06-02-2017 09-27-57.pngWeb - popup OAuth06-02-2017 09-26-57.pngWeb - Management console06-02-2017 09-26-25.pngWeb - Community
Domenico Langone
MCSD: App Builder
