Posted by wb6vpm
Henagon
Stop notification that TeamViewer is already running
I don't remember TeamViewer doing this until recently, but if I try to open TV from my start menu (FYI, I have TV set to run on startup), it gives me an error saying that "Another instance of TeamViewer is already running. Please close this instance before restarting TeamViewer." The normal (reasonably expected) result if I click on the icon when TV is already running would be for it to open the running instance, and not complain about there being an already running instance.
Please change the action flow to open the existing instance instead of popping up with what is essentially a useless and annoying pop-up window that just slows the agent down.
1 Accepted Solution
Accepted Solutions
Posted by TeamViewer Staff
TeamViewer Staff
Solution
Re: Stop notification that TeamViewer is already running
the problem should be fixed in TeamViewer 14.
Can you please let us know if you still got the message with the new version?
Cheers,
Julia
Posted by crackwitz
Henagon
I totally agree. This popup is useless. someone who starts teamviewer will ALWAYS want to see the main screen.
TeamViewer Staff
Our development is already looking at the issue. I hope we can provide a fix with the next update.
Cheers,
Julia
Posted by Djerdai
Henagon
This started recently for me and is annoying.
TV runs at Win10 startup  and this error message (TV is already running) popup occurs every time.
Task Manager shows...
    TeamViewer 13               .... 1.2MB
    TeamViewer 13 (32 bit) .... 1.0MB
    TeamViewer 13 (32 bit) .... 13.2MB
V  TeamViewer 13 (32 bit) .... 4.5MB
            TeamViewer 13
Posted by GlenWill
Henagon
Just adding my voice/vote to this issue.  I find it annoying, and found this page while searching for how to fix it.
Posted by RudolphP
Henagon
Same issue!
Windows 10, TeamViewer ver. 13.2.14327
Posted by nolly1953
Henagon
Ditto...
Posted by rockyx86
Electron
still very annoying.
Posted by RudieV
Digon
I am glad someone already posted this. It has been annoying me now for a some time and I thought I changed the settings. Good to know it is not a problem on my side.
So TV, please fix this small annoying alert, It will be much appreciated.
Posted by schmak01
Digon
Adding another vote to this,  so annoying.  Why the heck was this even put in? It was working fine before.
Posted by davem
Henagon
I thought it was the guys I was remote controlling doing something wrong. But no.
Just one in a long list of issues that seem to be added with each new version of Teamviewer. It's worked fine for years, why break it?
Black screen on connecting increasingly frequent, and on PCs I connect to regularly and without previous issues..
Failure to reconnect after remote reboot. Prompt for password after remote reboot.
Failure to display screen of 2nd monitor.
I've voted with my feet and switched to **Third Party Product**. It just works, no hassle, same remote hosts, same controlling PC.
Posted by davem
Henagon
**Third Party Product** just works when Teamviewer doesn't.
TeamViewer Staff
Solution
Cheers,
Julia
Posted by JITAdmin
Digon
That fixed it.
Posted by JITAdmin
Digon
Now that that works is there a way to always go back to Computers and Contacts instead of Remote Control? There is a quick connect bar at the top so I rarely go to Remote Control at all.
Posted by RudieV
Digon
Thanks for the message but a litte too late. I switched to another app which works faster, takes little resources and does not show the annoying and accusing message that I am using TV commerically.
Take care all. I am gone!
Posted by palmatech
Electron
Could you please share which applicatio are you using?
Posted by RudieV
Digon
I want to share this but the moderator software will delete the name. But perhaps by this way it might work **Third Party Product** the software is called and so far I am very happy, Takes very little diskspace and resources, much faster as well.
Posted by nolly1953
Henagon
Thanks Julia - all seems well now.
Posted by camcol
Electron
After upgrading to 14. We still get the notification that TeamViewer is already running.
Posted by Mike-McC
Henagon
I'm confused, your posts are showing up as '**Third Party Product**' - are you doing that yourself, or does TV forums actually substitute the names (like **Third Party Product** or GoToMyPC) of competitors?
Edit: Yep, they're substituting it.. weird.
TeamViewer Staff: Is there a legitimate reason for this outside of stopping people from recommending competetors alternitaves?
Posted by RudieV
Digon
Yes the bot is replacing it automatically. The bot is not too smart. If I write **Third Party Product** it usually does not see the name of the good alternative.
Posted by TimonMi
Neutron
So you are telling me we should spend another thousand of euros for a new license to be able to use teamviewer like it already did before?
I have at least a workaround:
Create a batch-file with the follwing content (replace the Path to you teamviewer executable according to your installation)
taskkill /im TeamViewer.exe
"C:\Program Files\TeamViewer\TeamViewer.exe" %:: replace the path here
This will kill the process and open a new one. Then replace all your shortcuts to the batch file. Works.
