Posted by MuTk0
Digon
Using TeamViewer on Galaxy Note 8 with S-Pen
I'm using TeamViewer sometimes to access my home PC trough my Android device.
It is a phablet with 6.3 inches display and supports S-Pen which I'm not able to use with TeamViewer's remote sessions. Based on this article ( https://community.teamviewer.com/t5/Knowledge-Base/Touch-Interactions-vs-Mouse-Interactions-on-Andro... ) with "*Note: For supported Android tablets, the display size must be at least 6.5 inches to have both Touch and Mouse modes available." - is it possible to add 6.3 inches devices to the supported devices for both Touch and Mouse availability?
It will be a great and very useful feature.
Thanks.
Posted by Larss1
Henagon
Re: Using TeamViewer on Galaxy Note 8 with S-Pen
I have the same problem, I actual bought the note 8 to use teamviewer with the s pen.
Posted by MuTk0
Digon
Hope TeamViewer team to add this feature soon :)
Posted by Pash74
Photon
Please add this feature... I bought the Note 8 so I can use the precision of the s-pen so select areas of the screen. The screen size on the note 8 is good enough that I can see the whole desktop on my screen at once. This is really disappointing!!
Posted by Rail
Photon
Please Team Viewer add this feature. The Samsung Note 8 was made for your application!
Posted by adufilie
Neutron
I have the same exact problem.  The feature is already there.  All that has to be done is to change the hard-coded number from 6.5 to 6.3!
Posted by ZiiTtTTTacEss_D
Photon
Even with no wifi, at verizon download speeds avg. 35-40mbps hotspot. Galaxy note8 N950U.
q2 ' boot L-2. Not permitted on TMv13. back to version 12. With 5g around the corner, Tm v 12 should work great i hope
Posted by Anonymus91
Photon
Is there any way to activate touch mode on note 8?
Posted by Horie
Photon
Mesma coisa aqui, fix it plz!
Posted by DomiNote9
Henagon
I have the same problem with my Galaxy Note 9. Any solutions?
Posted by MuTk0
Digon
Unfortunately NO :(
