How do I use the monitoring checks integrated into TeamViewer?
100% helpful (4/4)
Read this article in ChineseFrenchGerman | Japanese | Spanish
This article applies to all TeamViewer users
With TeamViewer, you can now monitor your devices remotely in order to oversee important hardware and software status information.
Some checks are integrated into TeamViewer and do not require a TeamViewer Remote Management subscription. These specific checks are freely available for personal use as well as with your TeamViewer license.
The following four checks are integrated in TeamViewer itself:
  • Disk space:
    Alerts you if the available hard drive space drops below 10%.
  • Windows Update:
    Alerts you if Windows Update is switched off.
  • Antivirus protection:
    Alerts you if no antivirus software is installed, or the antivirus software is out of date.
  • Windows Firewall:
    Alerts you if the built-in Windows Firewall is switched off.
Please assign the device which you would like to monitor to your TeamViewer account in order to receive alerts in your Computers & Contacts list, as well as in the TeamViewer Management Console. By assigning a device to a TeamViewer account, the device can be remotely managed and monitored by the account at any time.
To learn how to disable these alerts, please see "How can I disable the alert messages in my Computers & Contacts list?"
Version history
Revision #:
9 of 9
Last update:
‎11 Dec 2019, 5:29 PM
Updated by:
Tags (2)
