This article applies to Mac users in all  licenses.
TeamViewer’s multi-monitor support allows users to connect to devices with multiple monitors and view these monitors easily.
Requirements
To be able to use this feature, you must meet the following requirements:
  • You are using TeamViewer 13
  • You are a private user or own a TeamViewer 13 license (or higher)
Specification
If you are remotely connected to a device with multiple monitors, you can easily switch between these monitors from the TeamViewer remote toolbar. If you have the same number of monitors or more than your client, it is also possible to mirror them one-to-one onto your own monitors.
Hint: TeamViewer can only capture what the remote device has attached to it. For example, if the remote screen only has one monitor we cannot generate additional monitors. We provide you the physical state of the remote device.
With TeamViewer 13, Mac computers with multiple monitors work exactly the same way as Windows devices. Learn more about the Multi-Monitor support for Windows.
How to switch between monitors
In the TeamViewer toolbar, click on the View button then the Active monitor in the menu.
How to select a monitor
Select the number of the monitor that you want to view, click  Show monitor 1 , or Show all monitors to see all screens at the same time in a single window.
How to make tabbed connections in MacOS
To make the connections tabbed please open two connections to the devices or same device you wish to have tabbed.
Hint (Licensing): Opening two connections from your device will only use one of your channels.
In the Mac tool bar please go to Window, then select Merge All Windows
Screen Shot 2018-06-21 at 9.30.32 AM.pngMerge All WindowsScreen Shot 2018-06-21 at 9.30.47 AM.pngTabbed connections in one WindowIf you wish to have multiple monitiors of a remote system in seperate windows just make multiple connections to the same device and change the monitor on one of the connections and place the windows where you wish.
Version history
Revision #:
2 of 2
Last update:
‎21 Jun 2018, 5:50 PM
Updated by:
Labels (1)
Contributors
