Read this article in: Chinese | FrenchGerman | Japanese | Spanish
This article applies to all TeamViewer users using a killernetworking card.
Issue
You might be experiencing connection issues with TeamViewer if you are using an outdated driver for your killernetworking card.
Identification
It has been identified that outdated drivers of the network card/ wireless or ethernet, are the cause for the connection issues.
What means outdated?
Outdated means all drivers which are not on the latest build provided by killernetworking.
Solution
Please update the driver of your killernetworking card to the latest build. The latest drivers can be obtained from https://www.killernetworking.com/killersupport/
Version history
Revision #:
4 of 4
Last update:
3 weeks ago
Updated by:
Labels (2)
