Highlighted
Posted by Remote Management Staff
Introducing Data aggregation and Check for string features for Web Monitoring!
Read this article in Japanese.
We have added new features for TeamViewer Web Monitoring to help you see more historical data.
Data Aggregation
  • The data aggregation functionality compiles the results of checks for longer periods of time than it was previously possible: 3 days, 7 days, and 30 days. This feature provides our users the ability to see more historical data on the Chart View dashboard for the benefit of spotting general trends more easily.
  • In case of at least 1 failure result, the aggregated Check Point will be shown as a red dot. If the user clicks on the red dot, the chart will show the detailed information about the failure, like date & time.
  • Check for string (Content matching) for Uptime monitors
    Our new "check for string" or "content matching" feature allows to lookup a text string in the source code of the monitored web site. Under Uptime monitors > advanced settings, Users can specify the text string to lookup. If the string is not found during the check, the monitor will return a failure status. Users can choose between “Should contain” and “Should not containScreenshot_181.png
Product Owner, Remote Management services
