Problem with teamviewer GUI in Debian
Hi
Debian 8, teamviewer 12 for linux, installed from .deb package.
The problem is similar as in this posts:https://community.teamviewer.com/t5/Linux/Teamviewer-12-don-t-show-GUI-on-Ubuntu-16-04/td-p/4216
https://community.teamviewer.com/t5/Linux/Teamviewer-GUI-not-starting-anymore/td-p/15693
https://community.teamviewer.com/t5/Linux/Teamviewer-12-don-t-show-GUI-on-Ubuntu-16-04/m-p/4216#M476
but the citated solutions dont work in my case.
Teamviewer does not start any more. When I try to start teamviewer from terminal, I see
Init...
CheckCPU: SSE2 support: yes
XRandRWait: No value set. Using default.
XRandRWait: Started by user.
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
and no GUI apears.
There is no information in the log file.
I tried to start the TeamViewer.exe file with by wine, which is included in the package, ant this is the result:
bozho@debian:/opt/teamviewer/tv_bin/wine/drive_c/TeamViewer$ /opt/teamviewer/tv_bin/wine/bin/wine TeamViewer.exe
err:wineboot:ProcessRunKeys Error running cmd L"C:\\windows\\system32\\winemenubuilder.exe -a -r" (2)
fixme:service:scmdatabase_autostart_services Auto-start service L"MountMgr" failed to start: 2
fixme:service:scmdatabase_autostart_services Auto-start service L"PlugPlay" failed to start: 2
fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
fixme:ole:CoInitializeSecurity ((nil),-1,(nil),(nil),0,3,(nil),0,(nil)) - stub!
fixme:heap:HeapSetInformation (nil) 1 (nil) 0
fixme:process:SetProcessDEPPolicy (3): stub
fixme:msg:ChangeWindowMessageFilter 233 00000001
fixme:msg:ChangeWindowMessageFilter 4a 00000001
fixme:msg:ChangeWindowMessageFilter 407 00000001
fixme:msg:ChangeWindowMessageFilter 49 00000001
fixme:ver:GetCurrentPackageId (0x19dea08 (nil)): stub
fixme:process:SetProcessShutdownParameters (00000100, 00000000): partial stub.
fixme:win:EnumDisplayDevicesW ((null),0,0x33d98c,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x33dcd4,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x33d98c,0x00000000), stub!
fixme:module:load_library unsupported flag(s) used (flags: 0x00000060)
wine: Unhandled page fault on read access to 0x00000004 at address 0x7eb76a69 (thread 0009), starting debugger...
err:seh:start_debugger Couldn't start debugger ("winedbg --auto 8 176") (2)
Read the Wine Developers Guide on how to set up winedbg or another debugger
I trtied to deinstall teamviewer, deleted all relevant directories and instaled again, but without any success.
Thank you in advance.
Bozho
Same here. Desperately looking for a solution for 2 months by now... :smileysad:
I hope TW13 will be released also for Linux soon...
You don't need to hope, you need to read annoucements
It's out!
[Update] TeamViewer 13For TeamViewer 12 we hope to have an update in the next days.
Linux Developer0
