Team Viewer Host for Raspberry Pi (armv7) don't work when system service disabled
I use Team Viewer Host (teamviewer-host_14.5.5819_armhf.deb) withRaspbian Stretch. I don't need autostart and I disabled system daemon (sudo teamviewer daemon disable). And now when I start Team Viewer Host manually its don't work. Window opens, but there is red point with text "Not ready. Please check you connection". I checked some times: enable and disable daemon, but all is ok when daemon enabled and don't work when daemon disabled
