Posted by r5965
Henagon
Teamviewer's GUI not starting in Ubuntugnome 18.04LTS
I have searched through the forum and followed some of the advice on getting TV13 to load. I have also asked in the Ubuntu support forum. Nothing is  working
 Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
after this point teamviewer does not launch.
I have done the following;
Reinstalled Teamviewer 13 amd64
Purged and installed  12 386version
Purged and reinstalled TV 13.2..13582_amd64.deb
I can no longer use TV and would like to do so. Notwithstanding others have also had the same problem I would appreciate some specific help.
Posted by TeamViewer Staff
TeamViewer Staff
Re: Teamviewer's GUI not starting in Ubuntugnome 18.04LTS
Try
* uninstall
* remove everything in /opt/teamviewer, /etc/teamviewer, /var/log/teamviewer13, ~/.config/teamviewer, ~/.local/share/teamviewer13
* reinstall
* in general, never start the UI from the command line, mainly because it poses the risk you do it as root/sudo which can break permissions on some of the files in above mentioned folders
Start the UI once from the menu. If there is still no success, do "sudo teamviewer ziplog". Do it soon, so the logfiles will be short. You could send it, later, but first you can investigate yourself.
You can have a look at the logfiles yourself, and if you see a screaming error message, post it here. Mainly look in opt/teamviewer/logfiles/$USER/* (which is logfiles/$USER inside the zip file)
Daniel
Linux Developer
Posted by r5965
Henagon
In case i had made a mistake in my previous install,  I have this evening completely reinstalled tV13. I would like to send you the TV log file as I can not see anything wrong with it.  Please advise how I can send it to you.
I confirm that I have carefully followed your instructions on installing
Robin
Posted by emptythevoid
Digon
I have a similar problem with Teamviewer 13 on Ubuntu 18.04.  It doesn't happen all the time, but I found the fix for me is to restart the teamviewerd service.
systemctl restart teamviewerd
This problem seems to occur only if my system has been up for a while.
Posted by r5965
Henagon
Daniel:
I posted a detailed message last week but it has ceased to show in the topic. Basically I followed your advice exactly and as it did not work for me I tried to upload the relevant parts of the log.  There was only one type of error message:
RemoteSettingsMDRelationshipWatchDog: DEVICE ISN'T A MANAGED DEVICE
It occured a few times in the TV13 logfile
In the install_TVD.log it had messages  about the daemon:
Try: systemctl enable teamviewerd.service
systemctl start teamviewerd.service
I hope you can help me out so that I can start to use TV13 with Ubuntugnome 18.04 AMD64
PS
When I tried today to reply again this error message appeared in the pre post message. I did not past html deliberately. I just copied the lines from the logfiles.
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed.
Posted by zoziano
Electron
I felt foolish after having similar issues and finding the solution, but since my errors are similar to yours, down to the module not found message, I thought I'd share in case it helps:
After reinstalling the  package for the third time, I noticed that it mentioned it was skipping building the modules for the new "low-latency" kernel because the headers couldn't be found. After following these steps, I was good to go:
Posted by r5965
Henagon
Thank you for posting your solution.
Could you please repost the steps you took.
Posted by Nouvist404
Electron
try to run the "sudo apt --fix-broken install" command. sorry for my english
