Create shortcut on Teamviewer for android
Sabotto
Sabotto Posts: 1
Hi!
Is it possible to create a shortcut for a connection to a given address with a certain password?
In practice I would like to do what you do with the desktop version (example:
C: \ Program Files (x86) \ TeamViewer \ TeamViewer.exe" -i <TeamViewerID> --Password <Password>
Can this same connection be created on the smartphone
without having to type in your address and password every time?
I clarify that I use an IP address of a VPN so the ID is not like 890234 but is 172.16.0.13
