Zoom control using Quicksupport (remote control Android from PC)
CostinR
CostinR Posts: 1
Is it possible to enlarge the controlled Android device (via Quicksupport) from PC, using the mouse? I don't have 2 fingers on my mouse to use for zoom :))
There are sometimes images with small text. When directly using the Android device, you just "zoom" into the image using 2 fingers. But when using mouse and keyboard to remotely control the Android device (via Quicksupport), how could we "zoom" into the remote screen?
Thank you,
  • smarcell
    smarcell Posts: 1
    I have the same issue. Has anyone figured out if there is a way to do this? My specific application is using an android with the camera remotely. I need to be able to zoom within the camera on the android phone being controlled from the PC.
