Posted by Taymasoff
Henagon
Could not connect to partner
This error started to appear with the last update on android. How can I fix this? Disabling IPV6 doesn't help.
1 Accepted Solution
Accepted Solutions
Posted by Moderator Moderator
Moderator
Solution
Re: Could not connect to partner
Hello @Taymasoff and @lise,
Thank you for your messages.
We currently have connectivity issues concerning the latest Android app.
You will find our latest statement on this topic here: https://community.teamviewer.com/t5/TeamViewer-14/Unable-to-conenct-in-LAN-network-from-android-devi...
French Community Moderator
Did my reply answer your question ? Accept it as a solution to help others.
Find this helpful ? Say thanks by clicking on the Thumbs Up button.
Posted by lise
Electron
Hallo! I connected recently between Windows and Android devices.
What types of devices do you have?
Posted by Taymasoff
Henagon
Android - Windows.
Windows - Windows working fine.
Moderator
Solution
