How to get remote access for Vsmart devices
Hi all, I need to know what requirements are needed in order to get complete remote control access for Vsmart devices. I have installed the TeamViewer and QuickSupport apps and the device is correctly paired to a PC but the remote control is not working. The Android versions that we are using are Oreo (8.1.0) & Pie (9.0). Thanks!
    Hello @Alberto_Mota,
    Unfortunately, Vsmart is not part of our supported manufacturers yet.
    You will find all the information you need in our Knowledge Base article here: Supported manufacturers for remotely controlling Android devices
    I hope that in the future, Vsmart will be supported.
  • Alberto_Mota
    Thank you for your response @JeanK
    Could you please explain to me what is the process or the steps to follow to be part of the supported manufacturers??
