Posted by Weltall900
Photon
No remote control tab for my Android device with TeamViewer Host
On this photo, why don't I see the remote control tab when trying to connect to my Android device with TeamViewer Host?  I have TeamViewer host installed on a few different devices and this is the only one with the problem.  What's the deal?tv.jpg
1 Reply
1 Reply
Posted by Ashark
Henagon
Re: No remote control tab for my Android device with TeamViewer Host
You should check if you have installed Add-on.
Also you should check if your device is supported.
See this page: https://community.teamviewer.com/t5/TeamViewer-General/Why-Can-t-I-Control-my-Android-Device/td-p/34...
