Announcements
Are you new to TeamViewer and Home Office and do you need some help? Check out our FAQ here.
Highlighted
Posted by
Electron
Remote Control
Hi Guys
Just bought a Android box Sunvell T95Z Plus. Running on Android 7.1.1
I installed Teamviewer QuickSupport as I was trying to configure the box using Remote Control.
When I connect my Windows computer to the box, it does not allow me to Remote Control the box. Only Screenshot shows up.
This is the second box I have and I connect to the first one no problems at all.
Thank you in advance.
1 Accepted Solution
Accepted Solutions
Highlighted
Posted by
Electron
Solution
Re: Remote Control
SOLVED
Needed to install QuickSupport Add-On.
View solution in original post
Highlighted
Posted by
Electron
Solution
Re: Remote Control
SOLVED
Highlighted
Posted by
Photon
Re: Remote Control
Which add on did you install?
