Posted by DONNA2
Henagon
Using Trial Version 14. Trying to get remote control of Android Phone to work.
I have tried everything suggested in knowledge base, etc but cannot get remote control of Samsung Adroid phone to work. I have Teamviewer 14 trial version installed on my PC and Phone,  am using teamviewer for personal use only. Trying to help mother to fix her Samsung phone. I had her install Teamviewer Quick Connect and it sends me the ID and password but will not let me connect. I have tried to connect both from my phone and the laptop. I prefer to use the laptop for support as it is easier to navigate. I can connect to her PC with no problems but on the PC she has installed Teamviewer 14. Please help as I have tried all suggestions so far.
How do I connect from my laptop to my mohter's Samsung phone? Quick connect doesn't seem to work.
1 Reply
1 Reply
Posted by Moderator Moderator
Moderator
Re: Using Trial Version 14. Trying to get remote control of Android Phone to work.
Hello @DONNA2
Probably, the Samsung Add-on is not installed on her phone.
Make sure it is installed: Samsung Add-on
Cheers,
French Community Moderator
Did my reply answer your question ? Accept it as a solution to help others.
Find this helpful ? Say thanks by clicking on the Thumbs Up button.
