Highlighted
Posted by dece
Electron
Re: Why Can't I Control my Android Device?
Same issue - Moto X4 running Android 9
Highlighted
Posted by kostas1
Photon
Add-on for Zebra Handheld TC56
Hello i would like to ask if there is any add on for Zebra TC56. I am trying to remote control a device from quicksupport but there is no functionality and i am limited to view only.
Highlighted
Posted by Picard
Electron
Re: Why Can't I Control my Motorola Droid Turbo 2?
Downloaded the latest version of TeamViewer Host, got it up, but (like many others) it's only showing the screen and NOT allowing any kind of remote control.  When I clicked the little eject icon in the bottom right and clicked on the keyboard it said: "Remote side does not support remote input".
So despite Motorola being on the list of compatible devices, it's not working.
Highlighted
Posted by Nagmet
Digon
TeamViewer on BlackBerry devices
Hi.
Please remove TeamViewer from BlackBerry World. On BlackBerry10 this application does not work anymore. And disable the ban in the android application for use in BlackBerry10 devicesIMG_20190623_204505.png
Highlighted
Posted by btingle1
Henagon
Re: android tv box
Worked like a charm. Thank you.
Highlighted
Posted by Tomb1
Photon
Android 5.1.1
When connecting to Android 5.1.1, we have to 'allow' and then imediately select 'home' icon otherwise the tablet freezes and shuts down.
Juniper Systems, Mesa2 tablet
Any idea please?  Thank you
Highlighted
Posted by JRHPM
Henagon
Hi @Scotty
Nokia (HMD) is in the list of fully supported manufacturers. As you may see from the comments at the Google Play Store's "Add-On: Nokia", which is required to unfold the full capabilites on Nokia 8 smartphones, there is a malfunction during the installation process for this add on. (Google Play Store: TeamViewer Add-On: Nokia) It does not install.
Add-On: Nokia does not installAdd-On: Nokia does not installPlease review the "Nokia" add-on for Nokia 8 and let us know, when it works! Thanks!
JRHPM
Highlighted
Posted by niribiun
Electron
Mi Box S
Can I use TeamViewer with Mi Box S (Android 8.1)?
Specifications
  • Output Resolution: 4K (3840 x 2160)
  • CPU: Cortex-A53 Quad-core 64bit
  • GPU: Mali-450
  • RAM: 2GB DDR3
  • Storage: 8GB eMMC
  • Operating System: Android TV
Wireless connectivity
  • Wi-Fi: 802.11a/b/g/n/ac 2.4GHz/5GHz
  • Bluetooth: 4.1
Decoder
  • Video decoder: 4K@60fps,VP9, H.264,MPEG1/2/4,VC-1,Real8/9/10
  • Video Format: RM,MOV,VOB,AVI,MKV,TS,Mp4,3D
  • Audio decoder: DOLBY, DTS
  • Audio Format: MP3,APE,Flac
  • Image decoder: JPG,BMP,GIF,PNG,TIF
  • Support Language: Global
Socket
  • HDMI2.0a: 1
  • USB2.0: 1
  • Power Interface: 1
  • Audio Out: 1
Highlighted
Posted by WildcatMidnight
Henagon
Why Teamviewer (from my Pc) can not Remote-control my Asus device (Smart-phone): Zenfone Max-plus(M1) X018d(Zb570Tl) - even if Teamviewer-host & Add-on_Asus(y) are already installed (but Screen-sharing is Ok)?
Highlighted
Posted by osaether
Henagon
Is there a list of devices that are known to work with TeamViewer Host? I would like to buy a device that is known to work.
I know there already is a list of manufacturers but unfortunately that is not enough. Both Motorola and Huawei are on that list but both my Moto G7 Play and Nexus 6P does not work with TeamViewer Host.
Highlighted
Posted by manojanand
Electron
I see Lenovo Android devices are supported for remote control. Whereas I am only able to view my device when I connect to the host.
Host Details : Lenovo A6 Note, Android Version 9, Android Security Patch Sep 5 2019. Also I tried Installing the available Lenovo addons for android.
I tried connecting  the host from Android Galaxy S9+ running Android 9 and Windows 10 PC, but I am not able to remote control the device. Also on the Windows, team viewer pops up a message  "device supports screen sharing only teamviewer".
Is this a know limitation ? any solution to the issue?
Highlighted
Posted by Sikred
Electron
I downloaded the latest Teamviewer version for Linux  and Android (both host and Quick Support). I'm getting an incompatible verisons error. I just downloaded each version right now.
Highlighted
Posted by rgutter
Henagon
Ditto. Moto X4 worked until upgrade to Android 9. Now have a non-dismissable notification re QS needing elevated access, which cannot be added through the UI.
Highlighted
Posted by NathanAbaca
Electron
Remotly controlling Denso RF Scanner
Hi There,
I am trying to be able to remotely control a Denso RF Scanner (running Android version: 7.1.2). I have been trying to get this working using the TeamViewer QS app with no luck at all. I can get onto the connection from the PC to the device, but it only allows you to veiw the screen and if you click, it puts up a big Blue Hand so that you could show someone where to click on the screen, but really I need to be able to control it remotely. I am a TeamViewer business user and would really like this to be supported, as we already use TeamViewer for a big part of our business.
Please if anyone has any advice or suggestions or needs any further information, please ask away.
Thank you!
Highlighted
Posted by SKM1
Electron
The same problem with Moto G6 Play after system update.
Any ETA?
Highlighted
Posted by myk4il
Neutron
Highlighted
Posted by DFI
Henagon
I'm having many of the similar issues. I'm using the latest licensed  version 15 manager and host on Samsung tablet running android 10. The host continues to go yellow on the manager. We tried many of the setting, leaving the tablet plugged into power and only having the screen shut off.  Also many apps we install from TeamViewer on the android goes black when we open it the first time. The user at the other end says it asking for permissions on new installed app. We cant see it. Try lexmark printer app...  if we roll the host back to version 11 would that work better? And will manager version 15 be able to access and manage the device?
Highlighted
Posted by Osamah
Electron
Add on for Realme 5
i can not contol real me 5 with my phone because there is no supported add-on for this device kindly suggest the solution
Highlighted
Posted by Moderator Moderator
Moderator
Re: Add on for Realme 5
Hello @Osamah
You can find a list of all supported manufacturers for remotely controlling Android devices here
Unfortunately,  Realme is not supported yet. So please contact our team via this form: Contact TeamViewer BizDev and let us know which devices you would like to control remotely. This way, we may be able to provide you with a TeamViewer QuickSupport app to remotely control your device, soon.
Thank you  in advance.
Nadin
