Posted by pierini1
Photon
can NOT connect (THL W200S)
i own a THL W200S android smartphone and i can NOT mirror it to my pc because, after i installed QUICK SUPPORT app on my smartphone, it says me:
"CONNECTION ESTABLISHED" but after one second it disconnects by his own like if it would crash immediately.
I heard i should install some ADD-ON but there is none available for my smartphone brand/model so do you have any suggest in order i can make teamviewer work on it ?
