Posted by ANON1
Henagon
Help deleting account!?!
@JoshP
I lost access to my acount with 2factor authentication enabled and can't locate the recovery code. Can teamviewer delete my account so that I can reuse my email adress to create a new account?
Posted by davnaim
Electron
Re: lost recovery code and wiped phone
How do I send a PM to you? I've looked everywhere. Thanks.
Posted by Ruben4
Photon
F2A: wiped phone and recovery code isn't accepted
Hi!
I wiped my phone thinking about my 2FA apps. Lucily I store all the recovery codes securely so I can reset everything. But the code for Team Viewer isn't accepted. What's the best way to delete or reset my account?
PS: I'm posting from a different account :p
Posted by lkptantan
Henagon
Re: RE: Security codes for two-factor authentication lost
Hi, i changed my phone and my auth app don't work anymore, i can't find my recovery code, what can i do ?
Posted by tarik01
Photon
I can't connect into my account
When trying to access my account of Teamviewer appears as blocked, I made the procedure to request a new password, however I do not remember the code of the two factor authentication, I tried to reset using the 16 digit token but only one red line appears on the page to disable the authentication of two factors.
Posted by tarik01
Photon
Re: I can't connect into my account
PS: I need to create another account to send this post
Posted by Markusss
Electron
Re: 2fa lost and doesn’t work
Hello, I've lost access to my old phone and I have 2 factor authentication on my team viewer account. I have alos lost my recovery code... I woud like to delete my account so I can create a new one. Thank you.
Posted by lydiap
Electron
Need help to deactivate my account
I need to deactivate my account, which had two-factor authentication. I can't deactivate on my own because I don't have the recovery code. I have a personal free account.
Posted by ericeheng
Henagon
Hi there,
Is there any mods that are available to help me out? I've misplaced my phone and had to re-format my computer (at different times but didnt think this through apparently).
Now, my teamviewer account is locked and I do not have access to it anymore. Would appreciate it if any mods out there will be able to help me with it.
Posted by Moderator Moderator
Moderator
Hii @ericeheng
May you send the affected email address to me in a private message?
Thank you in advance and have a great start into the new week :)
Natascha
Posted by TwanAriens
Electron
Lost recovery code and crashed phone
I am messaging you from a new created account since I lost my security code (due to a crashed phone). I also lost my recovery key which causes that I can't login on my original account (email removed per Community Guidelines).
Could you tell me what to do so I can recover my account?
With kind regards,
Twan Ariens
Posted by zamarrona
Electron
@Reyhan
I have the same problem. Can you send me a private message with further information please?
Posted by LiamK
Henagon
Two Factor Authentication
My phone screen broke so I cannot access my authenticator and I do not have a recovery code. I would like to access my TV account on my new phone. I still am still logged in to my account on my computer. Can you please help me access my account on my new phone?
Thanks,
Liam
Posted by dickey-mallory
Henagon
my phone died and I lost the recovery key for account. I dont care about the pcs attached to that account. I would just like to use the email again for my personal account. Can you help reset? I can reply from that address if you need proof I have access to that email address.
Posted by San_Konig
Henagon
Hi, I also have an issue login into my existing account. Somehow 2FA was activated on my account, but neither me as well as our company administrator have any idea who did that and no one seems to have a recovery code for my account. So could you please remove my account as well? It's for my company account, not this account.
Thanks in advance!
San
Posted by AndreValafa
Henagon
Re: 2 factor authenticator lost
Same problem here can you please help me too?
Moderator
Hi, @LiamK@dickey-mallory  and @AndreValafa
Thank you for your post and sorry for the late reply.
If your TFA issue has not been fixed, kindly Private Message me your TeamViewer account to the Community moderator please. We will assist you further once you have sent your account.
Many Thanks.
Posted by LiamK
Henagon
I posted that almost 2 months ago. I have since solved the problem
Posted by nblackmoon
Henagon
 I also have lost my recovery key and lost the app and need to have it reset
Robert
Posted by etipi
Photon
Hello, I also lost my phone and I don't have recovery code. It is unfortunate that Teamviewer does not have mechanism to recover accounts. Even I can recover my bank acccount. Even, posting a message to this forum requires login with the account I already can't login. Can you please let me to delete my account?
Posted by topolito
Henagon
I need help please. Same issue
Moderator
Hi, @nblackmoon@etipi and @topolito
Posted by Tylen
Henagon
Lost recovery code for 2FA
Hi Team,
I lost my security code for 2 FA after changing new phone. Are you able to help me remove the 2 FA for my free account or delete my accout?
Tylen
Posted by QuintonEd
Henagon
Lost 2FA Code - Need Account Deleted
I lost my 2FA key and from what I understand I need to have my account deleted and remake it. If one of the mods could delete both my primary and this account, that would be great!
