Hi @mts-arkil
Thanks for posting.
The IDC does not apply a password, it only ever applies the logo and policy etc.
Thank you for pointing out the article, this is not applicable to V13.2 or later.
I have updated the article with a note reflecting this and pointing to the new method.
The new MSI is rolled out using Parameters. So you would need to add a parameter to have the MSI pick up the TeamViewer_Settings.reg. The full article is here
If you would prefer to use the older method, you can download the MSI for V13.1 here
I hope this resolves this for you.
-Scotty
Hi Scotty.
Thank you for replying, I will take a look at this when I get the time.
-Mts
Hi Scotty.
I got the first part working, I've added a install package in our Deployment Console. So I've now got the way to rollout the installment of Teamviewer Host 13 (13.1) the way it should including the preferences I've added.
V13.1 uses the previous deployment method with a .reg file in the same directory and the Assignment tool if required.
I have the reg file and assignment tool in the same share folder as the msi package. But once It is installed it wont use the settings I added in the reg file nor the group it should be added to.
I just named the reg file teamviewer, so it cant be because the reg file needs to have the name, right? = "TeamViewer_Setting.reg"
Regards MTS
