Is there a way to keep Teamviewer running in the background of the apple or windows PC?
jschroeder
I'd need to confirm if there is something that can be ran to keep teamviewer running on the computer even if the end-user decides to exit out of the application if I have setup it for unattended remote access. I can't seem to find a way to fire up Teamviewer remotely if someone has exited out of the program.
1
After you login to Teamviewer in your PC, On your top left you will see Extras.
Under Extras, click Options
In General Tab, enable the option, Start TeamViewer with Windows.
And then you will be asked to enter a password for secure connection and then you are good to go.
hope this helps
