Posted by Charag
Photon
login security codes problem
Hi, I enabled 2 factor security mode in the teamviewer however, now i couldnt find the reset key and dont have secruity code to enter once i login with correct user name and password?
How can i disable it? security code login in my account?
1 Reply
1 Reply
Posted by Moderator Moderator
Moderator
Re: login security codes problem
HI @Charag,
Can you please provide the affected email address to a moderator in a PM?
Then, we are able to help you in this case.
Thanks in advance and all the best,
Natascha
