Posted by algorythm
Henagon
TeamViewer 14 turns down input and output volume in other applications on macOS
I'm using TeamViewer 14.0.13880 on macOS 10.14 Mojave.
I typically use other applications for communication when using TeamViewer. When I start a TeamViewer session though, it feels like TeamViewer wants me to use voice communication in TeamViewer, because it turns down the volume of all other applications, including my microphone.
I would typically use Discord or Skype when communication with people, though if TeamViewer turns down the volume everywhere, then it is completely useless to me. This forces me to use another program than TeamViewer, which is quite annoying I think.
1 Reply
1 Reply
Posted by andigedeon
Photon
Re: TeamViewer 14 turns down input and output volume in other applications on macOS
Same effect with TV 13.2.26558 on Desktop PC Windows 10 1809 (17763.134) with Skype (8.34.0.78).
Terrible.......
