Posted by nemikejr
Photon
Trying to connect to my home computer from my work computer but...
I am getting an Error popup saying "The trial license of your connection partner has expired.  As your connection partner uses TeamViewer commercially, either one of you (one of the connection partners) needs a valid TeamViewer license.   If you have any questions please don't hesitate to contact us!"
My work computer is running Server 2016 and my home computer is a Mac Pro 2008, the team viewer on the Mac says "Free license (non-commercial use only)" and the work TeamViewer doesn't have that yellow bar.
Plus every time I try to use the TeamViewer client at work it says it can't validate if it's been run on this device before...
Thanks, Mike
1 Reply
1 Reply
Posted by HuolSam
Digon
Re: Trying to connect to my home computer from my work computer but...
i think teamviewer doesn't offer a non-commercial use for servers .. i had the same problem before with windows server 2008.
