Posted by 2factorsucks
Henagon
Re: 2 factor authenticator lost
I forgot my two factor authentication recovery key and my old phone that had the info has been wiped. After reading through your forums it looks like you just need to delete my account in order for me to use it again. Is this something you can assist with? The account I'm writing this with is just a temporary account so I can post on your forum. I got a repsone from a user named Bernd but he just gave me the response below:
If you are a paid customer, contact support directly. If you are on a free account, reach out ot one of the forum Mods and they will work with you to get your account deleted.
This is a free account so I believe this is my only option. If you could assist with this I would be GREATLY appreciative!!!
Posted by NeonFlame
Henagon
Lost 2FA
Hi, I did something dumb, and accidentally deleted the 2FA for teamviewer from my auth app.  I then started panicking and searching for the removal key, and i have no idea where it is :(
I've heard it's not exactly easy to fix this problem.. but i've also seen posts here indicating i should make a topic and request help sorting this out.
Posted by trueonotTemp
Henagon
Re: lost recovery code and wiped phone
I also lost my phone and recovery code.
who can help me here?
also it should be better way to develop, doing by someone is not a wise solution. I think.
Posted by Wriley
Henagon
I am having the same issue
Posted by SimonTWUK
Henagon
I too have the same problem (no access to the 2FA code and can't find the recovery code), although I am still logged in on one PC.
Any help to disable the 2FA so that I can set it up again would be much appreciated.
Thanks,
Simon
Posted by tamboro
Henagon
Free account no solutions. Have to change your account.
If you have a bought account, enter in contact with teamviewer support. They help you very quick.
Posted by rickmla
Henagon
I got a new phone and TeamViewer is not listed in my authentication app anymore. I don't have my "16 digit recovery code" either. Please help!
Posted by ankar
Henagon
I need assistence to restore my main account because of lost Google Authenticator app on my old smartphone.
And I have a 2FA off code, but system does not accept it.
Please help me.
Posted by Keltaras
Henagon
Lost Recovery Code and Phone
Hello, I lost my recovery account and had to replace my phone so I don't have access to a two factor authentication code. Could someone help me please? The account is [email removed]
Posted by spseminara
Photon
2FA and locked out
I am trying to delete or recover my account which is requesting a forced password reset.  After I recieve the change password email and enter a new password, it asks for my 2FA code.  I no longer have this.  From what I read, it was recommended I delete my account, but i cant since my account is locked out.
What are my next steps?
Posted by lostmy2FA
Henagon
lost authenicator & do not have code to remove it
I got a new phone and wiped my old one, then realized the my authicator app didnt carry over the codes for Teamviewer, so im now locked out of my account.
From reseaching this issue on these forums, it sounds like Teamviewer support needs to delete my account? So i can then set it up again?
If thats the case please let me know who to PM with my account details.
Posted by dbrodsky73
Henagon
Hi @Jonathan
I wiped my phone and can't access my account. Can you please help me delete the account? The account is under [email removed]
Thanks,
David
Posted by Michalt
Henagon
After reinstalling Google Authenticator codes, I found out that I do not have the option to use it for Teamviewer, and then I found out that I can not find a security code and get into my account. Can you help and access your account?
Thank you for your help
Posted by lugiank2
Henagon
Can a MOD help me deleting my account? (Lost phone and security key)
I had to make another account to be able to post here, so there are two accounts to delete
Posted by Michalt
Henagon
I have no authorization after reinstalling Google Authenticator codes
I have no authorization after reinstalling Google Authenticator codes After reinstalling Google Authenticator codes, I found out that I do not have the option to use it for Teamviewer, and then I found out that I can not find a security code and get into my account. Can you help and access your account? My account is m.trobl@trobl.net Thank you for your help
Posted by midlertidig
Henagon
2FA lost and no recovery code
It's been a while since I logged in, and my 2FA is not working anymore. I used to have this on a "lastpass" auth app, but the codes aren't working even if its a auth for teamviewer as it shows.
Can you delete my account? (not this email on forum), so i can start over?
Posted by lugiank2
Henagon
Please help me reset 2fa
Henagon
Re: 2FA lost and no recovery code
Any admins here that can help us?
Posted by Wriley3
Photon
They messaged me that they won’t help because it’s a free account. Very annoying that they don’t have an automated recovery like every other company in the world. Lost codes for Snapchat, Facebook, Amazon, google, Instagram and a few others. They all were easily fixed with a quick sms message.
Posted by Mikaël
Electron
wiped my phone, so twofactor is lost and have no recovery code. please kill my account. Thank you!
Posted by samuelecar
Henagon
I'm thinking that there can be a solution to solve this problem. As google, facebook and other application there is the possibility to receive a code in other way (not only the authenticator), for example an sms, an email or other. So maybe the better way to solve the problem is to implement this alternatives.
Posted by iam4ncsu
Henagon
I have the same problem with my free account. (in fact i could not even log into the community with my normal account and had to use my backup email addy)
can a moderator please PM me on deleting my actual account email?
Posted by Mlacoco
Henagon
I've sent a PM to Jonathan, posted a new topic, and replied here.  What does it take to get any sort of response from anyone at TeamViewer?
At this point its looking like less trouble to just switch to AnyDesk or some other alternative.
Posted by Dan9
Henagon
2FA Reset
Hello, recently did a factory reset on my phone. I didn't back up my keys so now I'm locked out of my account on my phone. Fortunately I'm still logged in on my PC. Is there a way to reset 2FA on my account?
Posted by wideth
Henagon
2 factor authentication account deletion
Can you help me delete my account so I can turn of TFA? Sorry is this is the wrong place to ask.
Posted by singkwoklam
Electron
I have lost my 2FA recovery password and my iPhone is out of service,
so I cannot login or disable the 2FA,
I would like to ask anyone can help to reset my 2FA?
Thanks!
Posted by adampk17
Henagon
Lost Access to authenticator. Any recovery of account possible?
I replaced my phone and lost access to the Google Authenticator 2-factor codes I had for my Teamviewer account.
Is there anyway to recover use of my account?
(This account is not the account I lost access to, I had to create a new one in order to log on to the community)
Thank you!
Posted by Blackhawk846
Henagon
Lost Phone(2FA App) and Recovery Key
Hi.  Unfortunately, I have lost my phone and cannot locate my 2FA recovery key on my primary account, so I cannot login directly or login to the forums to ask for help.  Is there any way to request deletion of the account, so that I can create a new one.  Thanks.
Posted by NytSong
Henagon
Lost 2FA Recovery code
A friend of mine got a new phone and thought he'd saved his 2FA recovery code to ultimately get google authenticator setup on the new phone.  Turns out he either didn't save it or doesn't remember where it was saved.
I'd seen via other people's posts that he'd have to make a post here and wait for one of the mods to help him.  Unfortunately he can't even log in here to post without his 2FA code.
What ways could he contact someone to recover his account?
Posted by Faeton
Henagon
Hello
Sadly, I've found myself in the same situation. My phone was completely ko'd and I don't have the recovery code.
What can I do?
Posted by clukas
Electron
Hi @Jonathan
Any chance you can help me delete my account (A different account, not this one)as I have also lost my auth code and recovery code and would like to start all over without using a new email address.
Posted by d7e7r7
Henagon
Hello @Jonathan
I don't have my 16-digit recovery code and my phone got wiped by Samsung when they repaired it. I had a few unttended access computers stored in my account so wouldn't like to lost it. Is there any other way I can regain access to my account?
Kind Regards,
David Ritchie
The email address I used was [email removed]
Posted by Giorgos
Henagon
@Jonathan I lost my recovery code and reseted my phone so I don't have 6-digit verification code.Can you help me?
Posted by tonibert
Electron
Hi @Jonathan
Any chance you can help me delete my account as I have also lost my auth code and recovery code and would like to start all over without using a new email address.
This account i just created to send this message.
Many Thanks,
Posted by ilan316
Henagon
Hi @Jonathan
Many Thanks,
ilan
Posted by ilan316
Henagon
Hi @Jonathan
Many Thanks,
ilan
Posted by lmhellerstedt
Electron
Hi @Jonathan
Many Thanks,
Dan
Posted by JustTryin
Henagon
Same situation here. I managed to lose access to my previous account even if I'm still logged in on my machine.
I tried messaging Jonathan as well but, I'm guessing a lot of us have had that idea so messaging him is now disabled.
Posted by lukeohoward
Electron
I have lost my 2 factor verifcation as well.  I would appreciate help from a moderator in getting this fixed!
Thanks,
Luke
Posted by DongjunKim
Henagon
Please deactivate my account's 2-factor authntication.
@Jonathan
Dear Teamviewer Support team,
I wiped my phone recently and I lost my recovery code.
Can you deactivate my account's 2-factor authentication ?
My account is [email removed by moderator]
Help me please..
Thank you.
Posted by rmeli
Henagon
I lost my phone and also lost recovery code neither.
I have no idea how I get back access to my account.
please, let me know how I recover my account.
if necessary, you may delete my account so that I re-create
Posted by Bufo0036
Electron
Hi @Jonathan unfortunately I lost access to my account due to losing my recovery code. Could you help me out? Thanks
Posted by shawn1
Henagon
Moderator - Please delete my account - 2 factor auth issue with no recovery code
Title says it all, I just need a moderator to delete my account because my Google 2 factor authentication was lost when my phone was reset, and I can not find any evidence of getting a recovery code from Team Viewer. I need my account deleted, so I can re-create it. FYI - This is not the account I need deleted, the one I need deleted I cannot post from because I am locked out of it. If you PM me I will give you the email address associated with the account that needs deleted.
Posted by pzaloznyi
Henagon
Lost 2 factor authenticator
Hello, after factory resetting phone, i lost my 2-factor authenticator code generator, i also do not have access to a back up code. I was intstructed by phone support to create a post here to have my issue resolved.
Please let me know if any other information is required.
Thank you.
Posted by obsolete24
Henagon
Add me to the long list of people who have had something happen to the 2FA token app. I need to delete my old email account.
As I had to create a new account to post here.
Posted by SpirillumX
Henagon
Hi @Jonathan
My phone stopped recognizing my SIM card and I had to factory reset, and I haven't been able to locate my 2FA recovery codes. Could you kindly assist me in deleting my account (and this one) so that I can re-create and start over?
Thanks,
Matt
Henagon
Can you help me as well?
Posted by TxCountryLife08
Henagon
@Jonathanare you able to recommend a moderator or assist me in deleting an account that I lost the two factor authtication too?
Posted by dteunissen
Henagon
Please disable 2FA or remove account
Please remove 2FA form my other account [email removed by moderator] or remove my account entirely so I can create new one. My authenticator was wiped when migrating to my new phone and I can't find my recovery key anymore.
If you need more info, please message me and I will provide whatever you need.
Posted by fletchers2011
Electron
lost recovery code and authenticator
I need a moderator to message me because I need help after losing ym authenticator and recovery code.
If I can get my account back that would be great.  If not I need to at least have my primary email address deleted from TeamViewer so that I can reregister it to use again.
