TeamViewer is not necessarily needed for using TeamViewer IoT.
The TeamViewer full version is however needed to connect to a device via TeamViewer IoT. To use the monitoring capabilities, only the TeamViewer IoT agent is needed to be installed on the remote device.
Version history
Revision #:
1 of 1
Last update:
‎22 Nov 2017, 11:29 AM
Updated by:
Labels (3)
Contributors
