Device access is only possible via easy access. This means that access to the devices is only possible via your TeamViewer account.
You can’t connect to devices using ID and password. If you, therefore, have Two-Factor Authentication activated for your account, you have the maximum number of security levels activated to prevent misuse of your devices.
Version history
Revision #:
1 of 1
Last update:
‎22 Nov 2017, 11:29 AM
Updated by:
Labels (1)
Contributors
