TeamViewer IoT uses full encryption. Encryption is based on 2048bit RSA private/public key exchange and 256 Bit AES session encoding. This uses the same security level as https/SSL and is considered completely safe by today's standards. The key exchange also guarantees that the data transfer is completely encoded from client to client and that any routers or servers in between (including our routers) are unable to read or analyze the data stream. Security and privacy have always been a top priority during development.
Version history
Revision #:
1 of 1
Last update:
‎22 Nov 2017, 11:27 AM
Updated by:
Labels (1)
Contributors
