Read this article in ChineseFrenchGerman | Japanese | Spanish
This article applies to all TeamViewer IoT users. who monitor their IoT network.
This guide will provide an example of how to integrate with https://ifttt.com/ using TeamViewer IoT Webhooks.
On the TeamViewer IoT dashboard, you can configure Webhook alerts to integrate your IoT solution with many third parties.  Webhooks trigger further actions like sending a text message or sending a notification via your messenger like Telegram by using a service like https://ifttt.com/.
 After you sign up with Ifttt, click on New Applet to create a new applet:
Set a trigger by clicking on +this
Enter Webhooks on the search field and select Webhooks
After confirming, select an Event name for the trigger like alert
Then create the trigger and select a service like email
After creating the action, you will see a confirmation, that your Applet is configured, though you now have to configure the webhook and the action (email). So go back to My Applets and switch to the tab Services and configure your Webhooks
Then click on Settings to find your Webhook URL like
Copy the URL and enter it on your web browser
Remember, our trigger we configured earlier was alert so replace the "{event}" with alert on the URL and you now have the webhook URL, that you enter on the IoT dashboard under Add Rule.
Congratulations! You have successfully configured your trigger!
Don´t forget to go ahead and configure your email account at Ifttt and test the connection by entering the webhook URL on your browser and check your inbox if an email has arrived.
Version history
Revision #:
4 of 4
Last update:
‎05 Jun 2019, 11:46 AM
Updated by:
Labels (1)
