Read this article in ChineseFrenchGerman | Spanish
This article applies to all TeamViewer IoT users who monitor their IoT network.
General
The TeamViewer IoT Node.js SDK is a development kit to facilitate integration of sensors to the IoT Agent MQTT API to allow for secure data registration and transfer to your TeamViewer IoT Cloud.
Download & Installation
Step 1 - Install dependencies
The SDK requires the following to be installed on the device:
  • Node.js 6.14.0 (Recommended version 8.3.0) or higher Long Term Support (LTS) version
Step 2 - Download the SDK
Download the SDK by either Clicking on the link or using the command line:
  • TeamViewer IoT Node.js SDK
    wget https://download.teamviewer-iot.com/sdks/nodejs/v1.0.2/teamviewer-iot-sdk-nodejs-v1.0.2.tar.gz
Step 3 - Extract & install the SDK
Upon download completion, extract the contents of the application:
sudo tar -zxvf teamviewer-iot-sdk-nodejs-v1.0.2.tar.gz
cd teamviewer-iot-sdk-nodejs
sudo npm install
Step 4 - Run Examples
To run the SDK example, execute the following commands:
sudo node ./examples/create_metric.js
Version history
Revision #:
18 of 18
Last update:
a month ago
Updated by:
Labels (3)
