using AD connector in a multi-domain environment
We are looking to use the AD connector, but our TeamVewer users are spread out over multiple security groups in different domains.
When testing the integration on domain A, it looks like the the AD connector will deactivate all users not part of that specific domain, so how do we make it work that the AD connector will look at all domains and keep the active users of all domains, and deactivate only the users no longer found in any of the security groups.
Thanks!
We have the same problem. I created a support ticket, but i will also write it here in case someone already has the solution:
We were using the previous AD Synchronization script. It's quite old, but it had a variable named $dcLdapPort that we set to "3268" so that the script queries the Global Catalog, which returns results from the entire AD Forest (the normal "389" port only queries the local domain, and nothing else). This is needed, because we have an Universal Group in Active Directory with users from the main domain and two child domains, and by setting the port to 3268, it returned the users from all the domains.
As the old script is not compatible anymore, we tried to use the new AD Connector script, but it only detects users from the main domain. The new script seems to have no way for it to query the Global Catalog / changing the port for the ldap query to 3268. Fortunately we used the "test run" option to see what would happen, as it would have deactivated all teamviewer users from the child domains.
How can we get the new script working for all subdomains (the entire forest)?
