Is there a way to transfer file to remote machine using API
SBTrain
Posts: 1 ✭
I looked at several posts but could not find any API call to transfer files to remote machine using API. Can someone point me to an example to get me on right path. The closest I found in API documentation is under Appendix
URLs for Connections with Devices
start.teamviewer.com/device//authorization/password/mode/filetransfer File transfer (using password)
I could not find any examples on this usage.
I am sure someone would have done this before, any help is much appreciated.
Thanks,
SB
