I have several systems/industrial machines made of a blind PC where TeamViewer is running and a PC with a display to interact with the operator. The 2 PCs are connected together by an ethernet connection, but only the first one is connected to internet.
Is there the possibility to check if TeamViewer is running and is on-line ("Ready to Connect") from the second PC? The operators want to know if/when the system is online.
Using Visual Studio or other IDE.
Thank you.
