I am trying to get session information out of the endpoint api/v1/EventLogging with a script token.
The script token was created as described here: www.teamviewer.com/de/fur-entwickler/?t=1610546063597#create-script-section
I gave it the maximum of permissions to try out the API.
I put the script token into the „Authorization“ HTTP Header as Bearer, is that correct?
A GET request to webapi.teamviewer.com/api/v1/Ping gives the response „token_valid: true“.
A POST request to webapi.teamviewer.com/api/v1/EventLogging with the following JSON body
"startDate":"2019-01-01T14:00:00Z",
"endDate":"2020-01-31T14:00:00Z",
"Events": [
"StartedSession",
"EndedSession",
"IncomingSession",
"JoinedSession",
"LeftSession"
"EventTypes": [
"Session"
always gives as response:
"error": "invalid_token",
"error_description": "Access token does not have the required permissions for this function.",
"error_code": 2
Any idea what might be the problem here?
