Grant Easy Access not working with Custom Module
I created a custom module and followed the instructions for Mass Deployment.
I created a batch file to run this:
msiexec.exe /i "Path\To\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=YOURIDCCODE
ping -n 31 127.0.0.1>nul
Path\To\TeamViewer.exe assign --api-token=YOURTOKEN --grant-easy-access --group MyGroup
Grant Easy Access is not applied.
Group is not applied.
Can someone help me solve this problem?
  • flospi
    flospi Posts: 52
    edited March 2022
    If you install with the MSI anyway, you can do it all in one line:
    msiexec.exe /i "%~dp0TeamViewer_Host.msi" /qn CUSTOMCONFIGID=XXX APITOKEN=XXXX ASSIGNMENTOPTIONS="--alias %COMPUTERNAME% --group-id %TVGROUPID% --grant-easy-access --reassign"
  • Thanks Flospi for the info. Yes, I used this and it worked.
    @echo off
    msiexec.exe /i "Path to\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=xxx DESKTOPSHORTCUTS=0 APITOKEN=xxx ASSIGNMENTOPTIONS="--grant-easy-access --group @newPC" SETTINGSFILE="Path to\newhost.tvopt"
    exit
    I first installed the host to set up the options then I downloaded the tvhost.tvopt file.
    Then I created the batch file above and created a shortcut with admin rights to open command prompt.
    This works great every time.
