Hi
I am looking to create a MS Power Automate flow to remove old devices is it possible do via TV API calls ?
Yes it is possible.
Here is Poweshell script that you can invoke with Power Automate or any other scheduling tool :)
Sorry about the formatting. Dont know if this forum has code support posts.
$text = "YOUR TV API Key"
$bearer = "Bearer",$text
$header.Add("authorization", $bearer)
[Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12
$devices = (Invoke-RestMethod -Uri "Https://webapi.teamviewer.com/api/v1/devices" -Method Get -Headers $header).devices
# $daysAftert to disable is a variable set to from todays date and 90 days backwards. You can change it do desired value.
$daysAfterToDisable = ((Get-Date).AddDays(-90)).GetDateTimeFormats()[48]
foreach ($device in $devices)
if ($device.online_state -eq "Offline")
$ID = $device.device_id
$Lastseen = $device.last_seen
if ($null -ne $Lastseen)
$LastSeen = ($device.last_seen).Split("T")[0]
[datetime]$DateLastSeen = $LastSeen
if ($DateLastSeen -le $daysAfterToDisable)
Invoke-WebRequest -Uri "Https://webapi.teamviewer.com/api/v1/devices/$ID" -Method Delete -Headers $header | Out-Null
$message = "Deleted device: $($device.alias)"
Write-Host $message
$Lastseen = $null
