TeamViewer IoT Device SDK for Python
This article applies to all TeamViewer IoT users who monitor their IoT network.
General
The TeamViewer IoT Python-SDK is a development kit to facilitate integration of sensors to the IoT Agent MQTT API to allow for secure data registration and transfer to your TeamViewer IoT Cloud.
Caution: The Python SDK is currently being provided via IoT Labs for trial purposes as it may not be backwards compatible with future versions.
Download & Installation
Step 1 - Download the SDK
Download the SDK by either Clicking on the link or using the command line:
wget https://download.teamviewer-iot.com/sdks/python/v1.1.0/teamviewer_iot_python_sdk-1.1.0-py3-none-any.whl
Step 2 - Install dependencies
The SDK requires the following to be installed on the device:
- python 2.7.9 or version 3
- For details, reference: https://www.python.org/downloads/
Step 3 - Install the SDK
sudo pip3 install teamviewer_iot_python_sdk-1.1.0-py3-none-any.whl
Step 4 - Extract Package
unzip teamviewer_iot_python_sdk-1.1.0-py3-none-any.whl -d teamviewer_iot_python_sdk
Step 5 - Run Examples
To run the SDK example, execute the following command:
cd teamviewer_iot_python_sdk
sudo python3 ./examples/create_metric.py
1
