I have setup an alert using Monitoring to notifiy me if Process TeamViewer.exe is not running. TV emails the alert but in fact it must be running because I can remotely connect to the endpoint. Once the user, or I login on the endpoint the Alert is recovered. The same thing is happening with System Updates. When logged into the endpoint, all appears well. A short time later, an alert is generated that there are system updates available. If I log in, this alert goes away. I am using Win 10 on all devices with a custom install module with a policy as well as monitoring policies.
