Monitoring Error
hfusco
Posts: 1 ✭
My orginization is on a trial for the Monitoring & Asset Management, however we can't use the feature at all. When we try to view any details about a device, we either receive the "An unspecified error has occurred" message or "Sorry, an error occurred while processing your request. mWhjEmScDia-3-1-32-c7y." I can't find anything about the error code, any advice?
Hi hfusco,
Thanks for using Remote Management and for contacting us.
We will investigate the issue and respond as soon as possible.
Product Owner, Remote Management services0 -
I started a trial and I'm seeing the same issue. I only have 12 more days on the trial, it doesn't look like I'll be able to properly evaluate it.
