Cannot get the teamviewer device assignment to work after install on the full version.
Cooley3000
Posts: 2 ✭✭
I am trying to set up an unattended install on macOS BigSur. I am using the following command:
sudo /Applications/TeamViewer.app/Contents/Helpers/TeamViewer_Assignment -api-token xxxxxxxx-zzzzzzzzzzzzzzzzzzzz
- I have the full version of TeamViewer installed.
- It is running.
- I have Start TeamViewer with system selected.
- I have the correct API key
- TeamViewer and the assignment tool are both in the appropriate locations
I run the command and enter my password. A few seconds goes by and I am back at the Terminal command prompt. I open preferences and there is no account assignment yet.
I am deploying to at least 700 machines to start and if we have to manually assign each of them it is going to be a heavy lift for a small IT team. Hoping I can get some assistance with this issue. Thanks in advance!
I figured it out
Just had to add the -group switch
