Operating system: Linux
Version: 15.31.5
Release date: 2022-06-28
Hello @Matt_Gulick and @keirak,
Thank you for your messages and welcome to the TeamViewer Community!
Before going into a deeper investigation, could you please try to reinstall TeamViewer on your devices and check if it solves the issues?
Many thanks in advance.
/JeanK
@JeanK I am unable to log into the Teamviewer application. The app launches and I click on the "Sign-in" Tab but all of the fields are grayed out and I can't fill them out, thus allowing the app to log in. Apparently, this wasn't properly tested. Please provide link to a previous version so that I can get up and running again.
The recent update prevents me from connecting to my remote system (free, personal use).
When I select "Connect", it brings up a password dialog - same as prior system.
The issue is that the dialog closes before I can enter my password. I then get a message saying I must wait * seconds because of too many failed attempts.
Details:
teamviewerd.service:
[Unit] Description = TeamViewer remote control daemon After = network.target network-online.target dbus.service Wants = network-online.target Requires = dbus.service [Service] Type = forking PIDFile = /var/run/teamviewerd.pid ExecStart = /opt/teamviewer/tv_bin/teamviewerd -d Restart = on-abort StartLimitInterval = 60 StartLimitBurst = 10 [Install] WantedBy = multi-user.target
teamviewer.list
### TeamViewer DEB repository list ### NOTE: Manual changes to this file ### - prevent it from being updated by TeamViewer package updates ### - will be lost after using the 'teamviewer repo' command ### The original file can be restored with this command: ### cp /opt/teamviewer/tv_bin/script/teamviewer.list /etc/apt/sources.list.d/teamviewer.list ### which has the same effect as 'teamviewer repo default' ### NOTE: It is preferred to use the following commands to edit this file: ### teamviewer repo - show current repository configuration ### teamviewer repo default - restore default configuration ### teamviewer repo disable - disable the repository ### teamviewer repo stable - make all regular TeamViewer packages available (default) ### teamviewer repo preview - additionally, make feature preview packages available ### teamviewer repo development - additionally, make the latest development packages available deb https://linux.teamviewer.com/deb stable main # deb https://linux.teamviewer.com/deb preview main # deb https://linux.teamviewer.com/deb development main
Other files available on request.
Matt Gulick
